Teil 6 (C6)
45 Beiträge
• Seite 2 von 3 • 1, 2, 3
Re: Teil 6 (C6)
Technical Specs and Features in the 2012 Corvette Z06
2012 Chevy Centennial Edition Corvette Z06
2012 Corvette Z06 Features
Courtesy of Chevrolet
The following features define the 2012 Corvette Z06:
Fixed-roof body style optimizes body rigidity and mass; offered in three trim levels - 1LZ, 2LZ and 3LZ.
Wide front fascia with a large, forward-facing grille opening, a splitter along the bottom and wheel opening extensions along the sides to provide aerodynamic downforce.
Cold-air scoop in front of the hood that integrates an air inlet system for the engine.
Wide carbon fiber front fenders and carbon fiber floor panels.
Wide rear fenders with flares cover the massive rear tires and a brake cooling scoop in front of the wheels visually balances the fender extractor.
Ten-spoke spider-design wheels (18-inch front; 19-inch rear).
Four large stainless steel exhaust outlets.
Z06 badging on the carbon-fiber front fenders.
High-intensity discharge headlamps.
Optional carbon fiber hood and "CFZ" carbon fiber package, with carbon fiber roof, rocker extensions, front splitter and ZR1-style rear spoiler.
Optional Bose Premium audio system includes nine speakers (vs. seven in 2011), including new tweeters located in the instrument panel and improve Bose Nd next-generation bass performance.
Optional onboard navigation system with voice recognition is included with 2LZ and 3LZ models. It is a DVD-based system that uses a 6.5-inch (165 mm) color touch-screen display.
Optional Heads-up display is available on 2LZ and 3LZ models and includes Track Mode with g-meter.
505 Horsepower LS7 Engine and 6-Speed Transmission
The racing-inspired Corvette Z06 is equipped with the 505-horsepower (377 kW) LS7 7.0L (427 cubic inches) engine and built on a lightweight chassis.
The 2012 Corvette Z06 is offered only with a six-speed manual transmission - automatic not available - that is strengthened for the LS7's torque and incorporates a pump that sends transmission fluid to the front radiator for cooling. Upon its return, the fluid removes additional heat from the differential lube before returning to the transmission. A single-mass flywheel and lightweight, high-capacity clutch channel torque to the rear transaxle, with a limited-slip differential using enlarged ring and pinion gears.
The 2012 Z06 offers 0-60 performance of 3.7 seconds in first gear, quarter-mile times of 11.7 seconds at 125 mph and a top speed of 198 mph.
For a truly intimate and unique experience, customers who opt for the Corvette Engine Build Experience (option code PBC) can participate in the assembly of their engine at the General Motors Performance Build Center in Wixom, Mich.
Z06 Chassis and Suspension
Z06 capability is enhanced for 2012, with upgrades and new features for the available Z07 performance package, highlighted by new Michelin Pilot Sport Cup Zero Pressure tires. When combined with new-for-2012 Performance Traction Management (PTM) technology - which manages torque delivery for maximum performance - the tires are expected to help set new benchmarks for Corvette performance. Engineers estimate an 8-percent gain in maximum lateral acceleration, to more than 1.1g, and improved braking distance. The enhanced Z07 package's effectiveness was demonstrated with a new lap time of 7:22.7 around Germany's legendary Nürburgring, making it one of the fastest production cars to circle the famous track.
Corvette Z06 Options
2012 options available for the Z06 include a carbon fiber hood, a new Bose Premium audio system with nine speakers, and brake calipers offered in yellow, silver and gray (red calipers are standard on the Z06.) Corvette Z06 also celebrates Chevrolet's performance heritage with the optional 2012 Chevrolet Centennial Edition Corvette, which features a sleek black color scheme, unique design elements and Corvette's sports car technology. The special package is inspired by Chevrolet's racing-bred foundation and is offered on all Corvette models for 2012.
The following features define the 2012 Corvette Z06 Centennial Edition:
Carbon Flash Metallic black paint with satin-black graphics
Special badges that signify Chevrolet's racing history, including a graphic logo featuring an image of Louis Chevrolet on the B-pillars, the wheel center caps and the center of the steering wheel.
The historic Corvette crossed flags badge contains a small adaptation, with "100" in place of the traditional fleur-de-lis symbol, only for the Centennial Edition.
Unique Centennial Satin Black wheels, sized specifically to the respective Corvette models, including 18-inch/19-inch for Coupe, Convertible and Grand Sport; and 19-inch/20-inch for Z06 and ZR1.
Red brake calipers.
Magnetic Selective Ride Control is standard.
Ebony leather-wrapped instrument panel and doors complimented by red stitching also on the steering wheel, seats, console and shifter.
The seats feature microfiber suede accents on seats, steering wheel, shifter and armrests, which were first used on the 2011 Z06 Carbon Limited Edition.
Seat headrests carry an embossed centennial logo.
Available on all Corvette models via order code ZLC.
2012 Corvette Z06 Technical Specifications
two-door hatchback coupe with fixed roof; rear-wheel drive
Construction: composite and carbon-fiber body panels, hydroformed aluminum frame with aluminum and magnesium structural and chassis components
Engine: 7.0L V-8 LS7 (Z06)
Displacement (cu in / cc): 427 / 7008
Bore & stroke (in / mm): 4.125 x 4 / 104.8 x 101.6
Block and Head material: cast aluminum
Compression ratio: 11.0:1
Horsepower (hp / kW @ rpm): 505 / 377 @ 6300*
Torque (lb-ft / Nm @ rpm): 470 / 637 @ 4800*
Recommended fuel: premium required
EPA estimated fuel economy (city / hwy): 15 / 24 (manual)
Transmission: six-speed manual
Traction control: electronic traction control; Active Handling
Brakes: front and rear power-assisted disc with ABS with six-piston front and four-piston rear calipers, cross-drilled rotors; ceramic rotors w/ Z07 pkg.
Wheel size:
front: 18-inch x 9.5-inch (std); 19-inch x 10-inch (w/ Z07 pkg.)
rear: 19-inch x 12-inch (std); 20-inch x 12-inch (w/ Z07 pkg.)
Tires:
front: 275/35ZR18 (std.); 285/30ZR19 (w/ Z07 pkg.)
rear: 325/30ZR19 (std.); 335/25ZR20 (w/ Z07 pkg.)
Curb weight (lb / kg): 3199 / 1451
Weight distribution (% front / rear): 50 / 50 (Z06)
Red brake calipers.
Wheel size:
Tires:
Tom untr35 - Beiträge: 1026
- Fahrzeug: C5 torch red
Re: Teil 6 (C6)
Corvette C6 ZR1 Hero Edition
Als einziges Exemplar seiner Baureihe, besticht die ZR1 Hero Edition durch rote Akzente am Exterieur, spezielle Plaketten, zusätzliche Carbon-Komponenten und schwarz-rote Ledersitze, die den markanten Auftritt weiter unterstreichen. Sogar die Abdeckung des Motors erhielt rote Verzierungen, die sich durch ein Fenster in der Motorhaube bewundern lassen. Um die Echtzeit des ZR1 Hero Edition zu authentifizieren, signierten die Motorsport-Profis Ray Krawczyk, Harlan Charles und Tadge Juechter aus dem Corvette-Team die Unterseite der Motorhaube.
Re: Teil 6 (C6)
The second special edition, the Competition Sport, cost $3,350 for the Z51-equipped Coupe and $2,750 for the Z06. Included was: Dual-Mode Exhaust (for the Z51 Coupe) unique engine cover, racing pedals, custom race numbers, custom wheels, ebony/titanium interior and hood, roof, and rear deck stripes. The Z51 option by itself cost $1,695. These cars were built in the Spring of ‘09 only. Unlike the GT1 Championship Edition, there were no pre-planned production “limited run” figures. Total sales were as follows: 72 total units, 13 White Coupes, 39 Blade Silver Coupes, 10 Black Z06 cars, and 10 Blade Silver cars.
Re: Teil 6 (C6)
Chevrolet Corvette C6 Z06 carbon edition
Eine limitierte Auflage von 500 Stück. Ausgestattet mit dem Z07 package . Diese Edition wurde nur in den Farben Inferno Orange und Supersonic Blue ausgeliefert.
Z07 packege
-Larger radiator
-ZR1 stabilizer bars
-ZR1 Shocks & springs
-F55 Suspension knob on Console
-ZR1 ceramic brakes
-ZR1 wheels
-Black Carbon Fiber Roof
-Black mirrors, possibly also carbon fiber
-ZR1 rear spoiler
-ZR1 front splitter
-Carbon fiber rocker panel extensions
-2 New Colors: Inferno Orange (28U), Super Sonic Blue
-New Goodyear Eagle F1 SuperCar G:2 Tires
Max speed 323 kph (200.26 mph)
0 - 100 kph 3.6 s
0 - 100 mph 7.5 s
0 - 150 mph 17.0 s
1/4 mile 11.6 s @ 126 mph
Engine
Power 377 kw (505 bhp / 512 ps)
Torque 637 Nm (471 lb-ft)
Displacement 7 liters (427 ci)
Engine type LS7 V8
Engine location front
Z07 packege
-Larger radiator
-ZR1 ceramic brakes
-ZR1 wheels
-ZR1 rear spoiler
-ZR1 front splitter
0 - 100 kph 3.6 s
0 - 100 mph 7.5 s
0 - 150 mph 17.0 s
Engine
Engine type LS7 V8
Re: Teil 6 (C6)
Tolle Arbeit - Respekt !!! ![drinks [smilie=drinks.gif]](./images/smilies/drinks.gif)
zenzi - Beiträge: 924
- Bilder: 40
- Fahrzeug: C6 SS´10
Re: Teil 6 (C6)
Tja, die richtig geilen Modelle gibt es nur als Schalter...
- Bilder: 40
Re: Teil 6 (C6)
Hochinteressant das Ganze, vielen Dank Tom für die Arbeit die du dir gemacht hast,
Re: Teil 6 (C6)
Schließe mich an , danke für die Mühe Tom ![drinks [smilie=drinks.gif]](./images/smilies/drinks.gif)
Re: Teil 6 (C6)
Tom der Archivar!
Damit finden die Bots genügend "Nahrung", um das CG hervorragend zu positinieren.
Dafür ein großes DANKE Tom.
Beste Grüße
Re: Teil 6 (C6)
Chevrolet Corvette 2011 Jake Edition Concept
A special Grand Sport convertible concept vehicle that celebrates Corvette’s racing spirit.
Re: Teil 6 (C6)
Chevrolet Corvette C6 Z06X
The Z06X concept is based on the Corvette Z06 with the 1LZ equipment package, along with the Z07 Performance Package and CFZ Carbon Fiber Package. The 2011 Z06 with the Z07 package includes carbon ceramic brakes and Magnetic Ride Control, while the CFZ package offers body components that enhance aerodynamic down force on the race track, including a front splitter.Corvette is a mainstay on racing circuits ranging from LeMans to club racing. Chevrolet Corvette Z06X Concept suggests a new idea and components for transforming a production Corvette into a serious, closed-course track car.The Chevrolet Corvette Z06X Concept showcases how an enthusiast can leverage Chevrolet's expanding portfolio of performance parts to create a full-on track car. Chevrolet teamed with Pratt and Miller, partners in Corvette Racing in the American LeMans Series, to create this Z06X track car concept.
Re: Teil 6 (C6)
Super geile Berichte und Bilder, meinen aller größten Respekt vor so viel Arbeit und Recherche, Tom...
Wenn wir hier aber schon bei Teil 6 sind, wo finde ich dann Teil 1 bis 5 ??
Re: Teil 6 (C6)
Der Nicki würde sagen: Ich zieh die Kappe! Unser Beifall ist dir gewiss,
Re: Teil 6 (C6)
The Mystique of the 7-Liter LS7 Motor
für die,die ihn noch nicht kennen oder gelesen haben. Ein ,wie ich finde ,schöner Bericht zu dem sagenumwobenen LS7 Motor.
Ab Seite 17 ist auch etwas zu den Problemen dieses Motors geschrieben. Ohne das Interesse an diesem Berich schmälern zu wollen-wie gesagt man wird nicht dümmer wenn man ihn liest- doch dieses vorweg:
6,5 Motoren von 1000 haben laut Nachhaltung Probleme gemacht. Wenn diese Zahl -was wir jetzt einfach mal unterstellen-um 50% geschönt worden ist , sind es 13 Motoren von 1000 was aber nicht heißt ,dass diese einen Totalschaden erlitten haben. Sicherlich sind das 13 Motoren zu viel ,aber so etwas kommt nun mal vor -auch bei anderen Herstellern.
http://www.corvetteactioncenter.com/spe ... index.html
http://www.corvetteactioncenter.com/spe ... ine17.html
SG
Tom
SG
Tom
Re: Teil 6 (C6)
super Tom das Du das so pflegst.
ich empfinde 13 von 1000 nicht als zu hoch. Klar ist es ärgerlich aber ist eben nun mal so .
Re: Teil 6 (C6)
Da sieht man wieder mal, wie toll die C6 in den verschiedenen Versionen aussieht, finde ich Vette-typischer als die C7
45 Beiträge
