Anzugsmomente für die C5
Beitragvon dr.duck » 11.08.19, 11:03
Anzugsmomente für C5 (Nur zur Orientierung, die Werte können je nach Baujahr variieren)
Die Liste ist noch unvollständig...
(Werte in Ft. Lbs und Nm)
Bremsen
Brakeline/Brake Hose Fitting
At Caliper 30 (40)
At Master Cylinder 24 (17)
At Proportioning Valve 18 (13)
Brake Pedal Pivot Nut 29 (21)
Caliper Guide Pin Bolts 23 (31)
Caliper Mounting Bracket Bolts(1) 175 (125)
Master Cylinder-To-Booster Nut 21 (29)
Power Brake Booster-To-Firewall Nut 27 (19)
Wheel Lug Nut 100 (140)
Caliper Bleeder Screw 106 Inch Lbs. (12)
Motor
Air Injection Pipe-To-Exhaust Manifold Bolts 15 (20)
Camshaft Retainer Bolt 18 (25)
Camshaft Sensor Bolt 18 (25)
Camshaft Sprocket Bolt 18 (25)
Connecting Rod Cap Bolts
Step 1 15 (20)
Step 2 Additional 60 Degrees
Crankshaft Balancer Bolt
With Original Bolt To Seat Balancer 240 (330)
Step 1 With New Bolt 37 (50)
Step 2 With New Bolt Additional 120 Degrees
Crankshaft Oil Deflector Nuts 18 (25)
Crankshaft Oil Seal Cover To Block Bolt (Front & Rear) 11 (15)
Crankshaft Position Sensor Bolts 18 (25)
Cylinder Head Bolts (1)
Drive Belt Idler Pulley Bolt 37 (50)
Drive Belt Tensioner Bolt 37 (50)
Engine Mount Through-Bolts 70 (95)
Step 1 11 (15)
Step 2 18 (25)
Flexplate/Flywheel-To-Crankshaft Bolts (2)
Step 1 15 (20)
Step 2 37 (50)
Step 3 74 (100)
Flywheel Hub Collar Bolt (A/T) 96 (130)
Knock Sensors 15 (20)
Main Bearing Cap (3)
Inner Bolts
Step 1 15 (20)
Step 2 Additional 80 Degrees
Outer Studs
Step 1 15 (20)
Step 2 Additional 53 Degrees
Side Bolts 18 (25)
Oil Level Sensor 26 (35)
Oil Pan
M6 Bolts (4)
M8 Bolts 18 (25)
Oil Pump Screen Nuts 18 (25)
Oil Pump Screen-To-Oil Pump Bolt (4)
Oil Pump-To-Block Bolt 18 (25)
Oxygen Sensor 31 (42)
Rocker Arm Bolts 22 (30)
Spark Plugs 12 (15)
Starter Bolts 37 (50)
Transmission-To-Driveline Support Assembly Bolts 37 (50)
Valley Cover Bolts 18 (25)
Valve Lifter Guide Bolts 18 (25)
Water Pump Bolts 18 (25)
Water Pump Cover Bolts 11 (15)
Water Pump Pulley Bolts 18 (25)
INCH Lbs. (N.m)
Flywheel Cover Bolts 106 (12)
Fuel Rail Bolts 89 (10)
Ignition Coil Bolts 106 (12)
Intake Manifold Bolts (5)
Step 1 44 (5)
Step 2 74 (8)
Oil Pump Cover Bolts 106 (12)
Throttle Body Bolts 106 (12)
Valve Cover Bolts 106 (12)
Vapor Vent Pipe Bolts 106 (12)
Servolenkung
Adjuster Plug Lock Nut 50 (68)
Inner Tie Rod-To-Rack (74) (100)
Pinion & Valve Assembly Lock Nut 26 (35)
Pressure Line Fitting (Hydraulic Union) 20 (27)
Pump Mounting Bolts (20) (27)
Rock and Pinion Mounting 30 (41)
Steering Shaft Lower Coupling Pinch Bolt 35 (47)
Tie Rod Adjusting Hex Lock Nut 52 (71)
Tie Rod End Nut 18 (25)
(3)
Wheel Lug Nuts 100 (136)
(3) Tighten torque prevailing nut an additional 180 degrees
Lenksäule
Column Bracket-To-Instrument Panel Stud Nuts 20 (27)
Column Bracket-To-Upper Support Bolts 20 (27)
Flexible Coupling Nuts 20 (27)
Intermediate Shaft-To-Steering Shaft Bolt 35 (47)
Lower Intermediate Shaft-To-Steering Gear Box Bolt 35 (47)
Steering Wheel Nut 30 (41)
Steering Wheel Rotation Sensor 40 (54)
Upper Intermediate Shaft-To-Steering Column Bolt 40 (54)
INCH Lbs. (N.m)
Air Bag Module Screws 86 (9.7)
Dimmer Switch Nut & Stud 35 (4)
Ignition Switch Screw & Stud 35 (4)
Lock Cylinder Screws 22 (2.5)
Lock Housing Cover Screws 80 (9)
Support-To-Jacket Screws (1) 77 (8.8)
Turn Signal Switch Screws 30 (3.4)
(1) Steering column upper support assembly-to-column jacket assembly mounting screws
Vorderradaufhängung
Ball Joint Stud Nut (1)
Lower 50 (68)
Upper 33 (45)
Crossmember Mount Nut 81 (110)
Hub & Bearing Assembly Nut 70 (95)
Lower Control Arm Bolt
Front (2) 125 (170)
Rear Front Bolt(2) 107 (145)
Rear Rear Bolt(2) 71 (95)
Shock Absorber Bolt
Lower 21 (28)
Upper 19 (26)
Spring Retainer Bolt (2) 46 (62)
Stabilizer Bar
Insulator Bracket Bolt (At Frame) (2) 40 (54)
Link Nut (2) 55 (75)
Tie Rod Jam Nut 50 (68)
Tie Rod-To-Steering Knuckle Nut (1)(3) (3)
Upper Control Arm-To-Frame Nut 42 (57)
Wheel Lug Nut 103 (140)
(1) After tightening nut to specification, tighten nut further but only as far as necessary to align cotter pin holes. Do not loosen nut to align holes. Install cotter pin from rear toward front of vehicle.
(2) Tighten with vehicle at proper trim height.
(3) Must be tightened in 3 steps. First, tighten to 15 ft. lbs. (20 N.m). Second, turn additional 160
degrees. Third, tighten to 33 ft. lbs. (45 N.m).
Hinterradaufhängung
Front 107 (145)
Rear 70 (95)
Lower Control Arm Joint Stud Nut
Step 1 15 (20)
Step 2 3.5 flats
Step 3 41 (56)
Tie Rod End Stud Nut
Step 1 15 (20)
Step 2 160 Degrees
Step 3 33 (48)
Rear Crossmember Mounting Nuts (1) 81 (110)
Rear Drive Axle Spindle Nut 118 (160)
Rear Suspension Adjustment Link Nut 44 (60)
Shock Absorber Mounting Bolt
Lower 162 (220)
Upper 22 (30)
Stabilizer Shaft Insulator Clamp Nut
Lower 70 (95)
Upper 49 (66)
Stabilizer Shaft Link Nuts 53 (72)
Tie Rod End Jam Nut 44 (60)
Transverse Spring Mounting Bolts 46 (62)
Upper Control Arm Ball Joint Stud Nut
Step 1 15 (20)
Step 2 250 Degrees
Step 3 41 (56)
Upper Control Arm Mounting Bolt 81 (110)
Wheel Hub Mounting Bolts 96 (130)
Wheel Assembly Lug Nut 100 (136)
(1) Install NEW mounting nuts.
Differntial
Axle Cover Bolt 18 (24)
Differential Drain & Fill Plug 26 (35)
Differential Housing Bolt 41 (56)
Differential-To-Transmission Bolt 37 (50)
Drive Pinion Cartridge Bolt 41 (56)
Drive Pinion Nut 392 (531)
Driveline Support Assembly-To-Bellhousing Bolt 37 (50)
Flexplate Spindle-To-Driveline Support Assembly Bolt (A/T) 37 (50)
Input Shaft-To-Front Drive Shaft Coupler Bolt 52 (70)
Rear Bearing Assembly-To-Driveline Support Tube Bolt 48 (65)
Rear Bearing-To-Rear Drive Shaft Coupler Bolt 52 (70)
Rear Crossmember Mounting Bolt 81 (110)
Rear Shock Absorber Lower Mounting Bolt 162 (220)
Ring Gear Bolt 144 (195)
Shift Control Mounting Bolt 22 (30)
Shift Control Rod Clamp Bolt 22 (30)
Trans. Mount Bracket-To-Differential Bolt 37 (50)
Transmission Mount-To-Bracket Nut 43 (58)
Transmission Mounting Stud 31 (42)
Transmission-To-Driveline Support Assembly Bolt 37 (50)
Transmission-To-Rear Crossmember Nut 37 (50)
Vehicle Speed Sensor (VSS) Bolt 10 (14)
INCH Lbs. (N.m)
Rear Axle Cover Bolt 89 (10
Autmatikgetriebe
Converter Housing Bolt (Except Corvette) 55 (75)
Detent Spring-To-Valve Body Bolt 20 (27)
Extension Housing Bolt 35 (48)
Manual Shaft-To-Detent Lever Nut 25 (34)
Oil Cooler Pipe Connector 30 (41)
Oil Cooler Pipe Fitting 30 (41)
Oil Pan Drain Plug
Corvette 24 (32)
Except Corvette 30 (40)
Oil Pump Cover-To-Body Bolt 20 (27)
Oil Pump-To-Case Bolt 24 (32)
Park Bracket-To-Case Bolt 25 (34)
Torque Converter-To-Flexplate Bolt 44 (60)
Transmission Case Extension Bolt (Corvette) 16 (22)
INCH Lbs. (N.m)
Accumulator Cover-To-Case Bolt 124 (14)
Forward Accumulator Cover-To-Valve Body Bolt 124 (14)
Line Pressure Plug 124 (14)
Oil Pan-To-Case Bolt 124 (14)
Oil Passage Cover Bolt 124 (14)
PC Solenoid Bracket-To-Valve Body Bolt 124 (14)
Speed Sensor Bolt 124 (14)
TCC Solenoid Assembly-To-Case Bolt 124 (14)
TFP Manual Valve Position Switch-To-Valve Body Bolt 124 (14)
Valve Body-To-Case Bolt (1) 124 (14)
(1) Tighten valve body bolts in a spiral pattern starting in center of valve body.
Kupplung
Back-Up Light Switch 15 (20)
Driveline Support Assembly-To-Engine Flywheel Housing Mounting
Bolt 37 (50)
Exhaust Hanger Bolt 37 (50)
Exhaust Take-Down Pipe Flange Nut 15 (20)
Flywheel Housing-To-Engine Bolt 37 (50)
Flywheel Inspection Cover Bolt 18 (25)
Flywheel-To-Crankshaft Bolt (1)
Step 1 15 (20)
Step 2 37 (50)
Step 3 74 (100)
Intermediate Exhaust Pipe Bolt 37 (50)
Lower Ball Joint Stud Nut
Step 1 15 (20)
Step 2 Additional 3 ½ Flats
Step 3 Minimum 41 (56)
Muffler Hanger Bolt 12 (16)
Outer Tie Rod End Stud Nut
Step 1 15 (20)
Step 2 Additional 160
Degrees
Step 3 33 (45)
Pressure Plate-To-Flywheel Bolt 47 (64)
Rear Crossmember Mounting Bolt/Nut (2) 81 (110)
Reverse Lock-Out Solenoid Bolt 30 (41)
Shift Control Assembly Mounting Bolt 22 (30)
Shift Rod Clamp Bolt 22 (30)
Lower 162 (220)
Upper 22 (30)
Skip Shift (Gear Select) Solenoid Bolt 37 (50)
Tie Rod Jam Nut 44 (60)
Transmission-To-Driveline Support Bolt 37 (50)
Transmission Mount-To-Rear Crossmember Bolt 37 (50)
Transverse Spring Mounting Bracket Bolt 46 (62)
Wheel Hub Mounting Bolt 96 (130)
INCH Lbs. (N.m)
Clutch Actuator Cylinder Bolt 106 (12)
Console Retaining Nut 89 (10)
Driveline Tunnel Closeout Panel Bolts 89 (10)
Instrument Panel Trim Plate Screw 27 (3)
Shift Control Closeout Cover Nut 106 (12)
(1) Apply Threadlock (12345382) to all bolts.
(2) Always use NEW bolts and nuts.
Manuelles Getriebe
Backup Light Switch 15 (20)
Drain and Fill Plug 30 (27)
Gear Select/Reverse Lockout Solenoid 30 (40)
Intermediate Exhaust Pipe-to-Muffler Bolt 42 (57)
Rear Suspension Crossmember Mounting Nut 81 (110)
Reverse Lock-Out Solenoid 30 (40)
Reverse Lock-Out Solenoid Bolt 13 (17)
Inch Lbs.
Vehicle Speed Sensor Bolt 89 (10)
Anlasser
Battery Negative Cable Bolt 12 (16)
Inch Lbs.
Positive Battery Cable Nut 81 (8)
S Terminal Nut 35 (4)
Auspuff
Exhaust Manifolg Bol (1st Pass) 11 (16<9
Final Pass 18 (25)
Exhaust Manifold Nutz 15 (20)
Muffler Bolt 37 (50)
Muffler Hanger Nut 12 (16)
Pipe Brace Lower Bolt 37 (50)
Pipe Hanger Bolt 37 (50)
Oxygen Sensor 30 (42)
Inch Lbs.
Manifold Heat Shield Bolt 60 (9)
Ignition Coil Bracket Stud 106 (12)
dr.duck
Re: Anzugsmomente für die C5
Beitragvon dr.duck » 12.08.19, 14:26
Im Abschnitt "Bremsen" sind leider an einigen Stellen des orignalen Manuals die Angaben in Ft. Lbs. und Nm vertauscht, deshalb sind diese Angaben korrekturbedürftig (ich kann aber den Beitrag von gestern nicht mehr ändern). Richtig ist:
Bremsen
At Caliper 30 (40)
At Master Cylinder 17 (24)
At Proportioning Valve 15 (18)
Brake Pedal Pivot Nut 21 (29)
Caliper Mounting Bracket Bolts 125 (175)
Power Brake Booster-To-Firewall Nut 19 (27)
dr.duck
